Threads: 2
Thanks Given: 4
bought a 2006 1.6i a week ago. last 2 days the fan has come on after I turned the engine off. had a y reg 1.6i berlingo for 6 years before that and did not have this happen. fan stopped after a few minutes. can still take it back to the garage for tweaking if its a problem. is it normal for this model? anyone else experienced it (recently maybe?)
thanks
Threads: 32
Thanks Given: 13
I am pretty sure mine has continued running after switch off if it was already running.
I can't recall is coming on after switch off to my knowledge.
The following 1 user says Thank You to tucker for this post:1 user says Thank You to tucker for this post
• wandering
Threads: 2
Thanks Given: 4
Thanks for your reply, Tucker. I am a little concerned about it, only seen it on an old old VW camper before this.
Threads: 13
Thanks Received: 57 in 48 posts
Thanks Given: 7
Bearing in mind the temperatures we've been having I'm not surprised. When you turn the engine off, due to the lack of coolant pump operation and air flow through the rad you will get an increase in coolant temperature. This causes the fan to switch on, common on a lot of cars! I havent specifically looked at your model of bingo so don't know if the same applies but I wouldnt be overly concerned unless it does it in cooler temperatures. Is the temp gauge normally static? if so after turning the engine off wait in the vehicle until the fan cuts in and turn the ignition to position 2 but dont start. Watch the temp gauge and see what if anything happens.
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.
alut:
Threads: 13
Thanks Given: 7
If you're sure the level has dropped check to see whether the passenger footwell is damp i.e. the mat and underneath. The heater matrix's can weep. Not expensive for a new one (£30 ish) but a bit of a tit of a job!
alut:
Threads: 2
Thanks Received: 1 in 1 posts
Thanks Given: 3
10-08-2011, 07:30 PM
Fan running for a few minutes after you switch off is normal, particularly in warm weather.
