Thanks Received: 26 in 24 posts
Thanks Given: 52
16-03-2015, 02:20 PM
(This post was last modified: 16-03-2015, 02:20 PM by ATL_driver.)
can I just say, what a crock of s**t the standard jack is on my 63 plate berlingo, anyone else think this too? just took my knuckles off at the side of the A12 changing a puncture
63 plate Berlingo working hard.....
Threads: 52
Thanks Given: 87
5
I would have to agree with you although I have (touch wood) never had to use it on the road. Bad enough in the garage.
Threads: 16
Thanks Given: 46
5
Its not good, but it does the job. I wear thick work gloves when swapping my wheels around.
Threads: 27
Thanks Given: 20
13
I can't understand why they have that daft vertical piece in the sill to put the jack into.
Its very difficult to use a trolley jack under it at home.
Threads: 23
Thanks Given: 50
29
Wow never seen one of them before what is it called ??
Threads: 7
Thanks Received: 29 in 25 posts
Thanks Given: 42
4
(16-03-2015, 10:07 PM)Jed Clampit Wrote: Wow never seen one of them before what is it called ??
A jack pad, in recent times they have come down to sensible prices when you are buying them in one-offs. Plenty on ebay.
Mar 2002 Berlingo Multispace Forte 1.9D 166,000 miles
Thanks Given: 52
just think they designed the van for a decent jack and then just grabbed some cheap sheet one...
Threads: 63
Thanks Given: 410
(17-03-2015, 05:36 PM)Opensauce Wrote: (16-03-2015, 05:21 PM)Gollycrush Wrote: This is what you want when using a trolley jack. Available on eBay.
Cheers for posting that. I've ordered one. Searched ebay for 'jack pad'. I swap my wheels round every couple of months & I've never used my trolley jack because of damage danger, now I can.
Thanks gents,
Well, you live , you learn.... must admit it is a new one on me. Always used a bit of wood between trolley jack and metal but never on sills before.
Can I ask what size slot and O/D of pad do I need to order and yes plenty on e-bay for around a fiver. can't afford not to have one at that price...
