Threads: 23
Thanks Given: 46
5
It's just the plate that the rubber bonnet striker rests on.
Threads: 6
Thanks Received: 16 in 13 posts
Thanks Given: 11
Not the plastic "turret" type bits where the rubber on the bonnet rest. I meant the bit attached to the side of the nearside one, circled in red.
There are two fixing holes in the bonnet where it meets this part, with nothing attached. Just wondered what it was for??
Threads: 23
Thanks Given: 46
5
You are of course correct. I have no idea what it is/was for, mine is identical.
Threads: 6
Thanks Given: 11
17-03-2015, 11:41 AM
(This post was last modified: 17-03-2015, 11:41 AM by jamesg.)
Mine has always been broken off and the molding seems part of a much larger piece, so just wondering! Some kind of bonnet alarm extra??
Threads: 23
Thanks Given: 46
5
Here it is in all it's glory.
I have no idea what it's for, anyone??
The following 1 user says Thank You to Trevor for this post:1 user says Thank You to Trevor for this post
• jamesg
Thanks Received: 26 in 24 posts
Thanks Given: 52
I'm guessing it's a sensor to detect an open bonnet, for while I do not know, under bonnet lighting? or alarm maybe?
63 plate Berlingo working hard.....
Threads: 16
Thanks Given: 46
5
Mine broke off yrs ago & I cleaned up the break with a file. Maybe its to lift the moulding during production?
Thanks Received: 1 in 1 posts
It is for the sensor alarm. Not availeble in belgium no idea in england.
Sorry for bat english
The following 1 user says Thank You to Nowi for this post:1 user says Thank You to Nowi for this post
• doofer
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Whats the large plastic looking cover around the oil filler cap for? Dont think mine had it?!
I DO MISS MY BERLINGO
