16-03-2015, 06:43 PM
Hello All,
I would really appreciate any advice with regards to a broken Pedal Box on my 2005 2.0hdi Berlingo Multispace.
I will try to keep this as short as possible! I pressed the clutch pedal down there was a loud crack and the pedal was hanging at an angle and no gear change.
I managed to get it to my local garage who informed me the pedal box had cracked on both sides and to leave the car with them, when I went to pick up the vehicle I was told that they had managed to weld it as best they could in car, as to remove and replace the pedal box would be very expensive as the engine would need to be lowered to remove the servo unit and it would take a long time to do the job.
I have a Haynes Manual unfortunately the Pedal Box does not appear to be there but I did look at the Servo Unit and it never mentions dropping the engine for removing it or am I missing something?
If anyone has had this job done I would really appreciate your input as my knowledge of cars is somewhat limited!!
Thanking you in advance
Dessie
Dessie
