Threads: 7
Thanks Received: 29 in 25 posts
Thanks Given: 42
4
I don't know the specifics on these engines but if the (main) oil filter has an overpressure release valve, they often release when the oil is cold and thick or at high revs. Quite a few engines are going back to bypass filtering instead of full-flow as well, this means only a proportion of the oil goes through the filter. It seems that filtering isn't the catch-all we hope for.
Mar 2002 Berlingo Multispace Forte 1.9D 166,000 miles
Threads: 12
Thanks Received: 69 in 55 posts
Thanks Given: 7
ive met and talked with 7 people with b9 shape berlingo/partner vans on sites, 5 had no problems, 2 said they are a load of crap because the turbo went, neither were oil serviced properly and one said he had no idea what oil he just gets his mate to do it, I do mine every 6-7000. I believe the later 1.6hdi in the b9 had a better oil system to the earlier m59 shape van and are less prone to failure
Threads: 7
Thanks Received: 3 in 3 posts
Thanks Given: 4
Had my XTR 90 for a fortnight and am thinking of changing the oil as a precaution (even though the dealer (not Citroen) insists it has been done). Is the consensus to change it and the filter, every 6,000 miles?
I'd forgotten just how quickly the oil goes black on a diesel!
Threads: 23
Thanks Given: 50
29
Keep the Berlingo well serviced oil and oil filter a lot of short trip's 6000 mile's if you do longer trip's every 8000 mile's if you go to the dealer ask them they will be able to tell you which filter you have in the oil feed you can get a new one and change it then you can see the what the old one look's like i you don't have a FAP / DPF it's not to hard to do if you have one you'll have to remove it to get to the banjo bolt's a pain it just takes longer if it's clean you don't have to worry one last thing use the right oil
