Croydon based new guy.
Afternoon everyone.
Just joined you guys last night.
Had my 57 plate berlingo enterprise around a month now.
Bought it so I can set up my new oven cleaning and repair business.
Really impressed with the berlingo tho.
It's 1.6 hdi not too sluggish fantastic on fuel too over 600 mile to the tank Wink
I do have a question tho. Is it possible to fit the multi space rear door to mine?? I need to repair the door anyway so I'd rather the up n over door.
Chris
Hi Chris and welcome to the forum. I don't doubt that it would be possible to fit the other type door but I would have thought the cost would be prohibitive? Have a search through the forums you may find something about it.
Hi Trevor. Thanks for that. I was kinda hoping the bracket points maybe there.
If it can't be done it's no real issue.
Hello Chris welcome to the forum good to have you with us could be done but would be a lot of work i think more work than it's worth  Sad
Was just a thought mate.
No issue.
What wheels can I fit also lowering springs??
Gonna be used as a work horse but would like a few nice extras Wink
(29-03-2015, 01:15 AM)Chri5 Wrote:  Was just a thought mate.
No issue.
16" 17" 18" 7 j 7.5 j  C4 lowering kit you will only be able to use your old damper's on the rear as the C4 one's are to long  Smile
Will they be ok for the older shaped van??? What sort of drop will it give??
I can't drop the rear too much as I've a heavy water tank in the back.
(12-04-2015, 10:06 PM)Chri5 Wrote:  Will they be ok for the older shaped van??? What sort of drop will it give??
Sorry wrong model i think it's the 306 that will fill your's 20 / 30 mm or coil over's you can put them up and down when you need to
Thank you Wink
Will Saco vtr wheels fit?
Wiring route for parking sensors - 2013 Berlingo
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Citroen Berlingo K9 Touchscreen
Last Post: CB-K9murph
05-06-2026 05:47 AM
Berlingo 1.6 NFU it won't start
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Engine Fault Repair Needed, Emissions Fault Adbl...
Last Post: Desdinova
27-05-2026 10:15 AM
Reservoir tank
Last Post: Stevie3393
25-05-2026 12:34 PM
Using Ctek recovery mode insitue
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
