Berlingo 2 Heater Blower Problem
I realise that this has been asked before, but I couldn't find the answer to the problem for a Berlingo poverty model without air-con. The problem is that the heater blower only works on full blast - number 4 setting. At the other three settings it is dead.
My van is a 2003 Berlingo 2 with no air-con. The part required is this one....
[Image: 20130129101145321.JPG]
They are around a tenner on eBay.
It is located above the heater blower. However, you don't need to remove the blower to get at it. If you open the glove compartment locker and shine a torch through the gap at the top you will see the plastic part of the unit to your right at the same level as the gap you are looking through. Reach under the trim below the glove box and unclip the plastic part. Then you can bring it out and unclip the wiring loom. No tools required! Re-fitting is a simple, reversal of this procedure.
I had a slight problem in that the white plastic moulding wasn't quite the same as the original and wouldn't just clip back in securely. Now, I reasoned that this resistor must be located where it is for a reason - to keep it cool and so I didn't re-locate it under the dash, but stuck it back in the right place using some glue.
[-] The following 1 user says Thank You to Nicepix for this post:
  • ron
Hello Nicepix welcome to the forum good to have you with us Thank you for the wright up and photo perhaps some one for moderator team can move it to the howto section
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
