  • 6 Vote(s) - 3.17 Average
Engine Flood Damage Help!!!!
just drove the van through a small ford and it just stoped.. is there anyway of curing this problem????
any help would be really good
Thanks in advance,
Kersh
Did it just cut out? Does it turn over now or anything...? And how deep did you go?
it just cut out completly and to just over the bottom of the bumper and didnt turn over..
Have you fixed it yet? Is it a petrol or diesel ? If it is still not going take the air filter and plugs out (spark or glow) then try to turn the engine over this should get rid of any water out of the engine.Then put them back in and try to start.
If it is a deisel it might have bent a rod or jumped a tooth on the timming belt depending how fast the engine was running when it sucked up the water.
The air filter is quite low so always make sure that the clips are done up.
Kersh. What engine in your Bilingo? Otto or Diesel?
Hi, Where is the lowest point that air is sucked in? Is there any way to seal this and have it only taken in higher up at the bonnet cross member? It concerns me as the road to work floods sometimes! xx bigsacs
Don't have a "Nuts and Bolts" solution but sounds like you need a tube or "snorkel" for want of a better description. I know they fit them to Land Rovers together with high level exhausts. You would probably have to get something fabricated.
I have seen footage of Landy's completely immersed and still going but I don't think I personally would put my Berlingo through all that....
hi big sacs
did mean to worry anyone the air intake is fairly high on most of the engines.What I was meaning was the air filter housing its self is quite low and if it wasn't clipped on properly then it could suck the air in there but if it is on properly it wont suck in from there.
(10-12-2010, 11:02 AM)bigsacs Wrote:  Hi, Where is the lowest point that air is sucked in? Is there any way to seal this and have it only taken in higher up at the bonnet cross member? It concerns me as the road to work floods sometimes! xx bigsacs
How about doing something like this?
[Image: 2003Bourlingeuer.jpg]
or modifying something like this?
[Image: 555_2_906.jpg]
I think you might get a few comments from the off-road fraternity though!
Eolys replacement tank
Last Post: Harrythephot
Yesterday 12:02 PM
Yesterday 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
