[Transmission] WHINING NOISE
Threads: 69
Thanks Received: 22 in 22 posts
Thanks Given: 7
4
ello, u all ok ? last few weeks i have noticed a deep whining noise in low gears when pulling away from standstill,when going up the gears this noise disappears,any suggestions ???( its going in next week to have a new clutch,because its very very heavy to depress) thanks in advance MY MUCKER
 nice to be important,more important to be nice
my ride is a berlingo forte 1.9d 2003 model in pukey blue
Threads: 20
Thanks Given: 2,126
18
Input shaft bearing?
Strawberry flavoured windows
Threads: 69
Thanks Given: 7
4
(12-04-2015, 09:21 PM)ron Wrote: Input shaft bearing?
thanks Ron much obliged,and what is that in laymans terms or dumbos like me,can this be repaired when the clutch is being renewed??? (this week)
Threads: 20
Thanks Given: 2,126
18
(13-04-2015, 07:12 PM)my mucker Wrote: (12-04-2015, 09:21 PM)ron Wrote: Input shaft bearing?
thanks Ron much obliged,and what is that in laymans terms or dumbos like me,can this be repaired when the clutch is being renewed??? (this week) Gearbox out is necessary & probably require stripping but DON'T do it on my say so.Get a good mechanic to listen to it. The shaft that pokes out into the bell housing is the g/box inputshaft.The bearing is what supports it.Some can be removed from the bellhousing but most require a g/box strip.I'm not familiar enough with the Berlingo box to know.
Threads: 69
Thanks Given: 7
4
ok Ron very much obliged indeed,i'll have a word with the fitter who'll be doing the work and perhaps he can have a listen to determine what it is,anyway thanks again Ron
Threads: 69
Thanks Given: 7
4
Threads: 20
Thanks Given: 2,126
18
Threads: 20
Thanks Received: 23 in 20 posts
i had this on my pug partner .
clutch release bearing when it has no tension on it at low revs would really audibly whine and when you got it up the gears if oyu listened really hard with your foot off the throttle it would whine then also.
If your clutch is going ill bet the release bearings also gone...
While your doing the clutch i suggest doing the mainseal , the clutch cable and the gear box linkages for the extra 40 quid it will cost. Drives like a shiny new pin again
Threads: 69
Thanks Given: 7
4
thanks anyway Ron catch you again s'pose,you too top drive, ye i've enquired about the linkages on another thread,trying to gather info to do it myself.thanks for your input, MY MUCKER
Thanks Received: 22 in 16 posts
Thanks Given: 36
I too suffer from a whining noise when I drive with the wife in the car. Funny though, it disappears when she gets out!!!! ?
2014 Berlingo Multispace 1.6 e-Hdi XTR ETG6
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
