ECU software: This probably affects all DW8 1.9D engines
A certain master tech wrote (pasted below) that the ECU software needs to be updated at the dealer.  Apparently this engine has a known problem with the ECU related to the advance solenoid.  I will ask the dealer and see what they're willing/able to tell me.
Relatedly, I've had:
Replaced Advance Solenoid
Still the occasional random "automatic revving" of the engine
Current lack of acceleration at RPM's over 2800 (MAF sensor, TPS sensor, I don't know yet)
Ok so here's the posting from the web, the guy had a bunch of misdiagnosis issues that led to replacing all the injectors without any solution.
Berlingo 1.9D:
Berlingo woes! Please help! - brayer
hi there
i work as a master technician in a peugeot dealer ,as you know this is the same vehicle as a peugeot partner,this is a know problem with this engine all you need to do is ask your citroen dealer to download new software in to the engine ecu ,the fault is caused by the advance solenoid in the injector pump locking up,when turning off ignition this resets it.and the fault goes away for a while.i'm surprised they haven't done this yet but i see no mention of it in your message.also be very careful of the oil level in this engine as being slightly overfilled will cause rattling and smokeing problems.hope this is some help
regards
paul bray
http://www.honestjohn.co.uk/forum/post/?t=30322
[Image: 177657.png]   2004 1.9D DW8 WJY with black spray paint on wheels instead of flimsy plastic wheel covers.
[-] The following 3 users say Thank You to teddyc1 for this post:
  • Arbe, bikergraham, brajomobil
DPF Filter "do I really need it"
Yesterday 11:06 PM
Water inside door
Last Post: Buki
Yesterday 10:07 PM
Berlingo MK3 (K9) seats
Last Post: Vincent Rooke
Yesterday 10:21 AM
First cold startup metallic noise.
10-11-2024 09:57 PM
New Van - 2017 B9 BlueHDi build
Last Post: sciteacher
10-11-2024 04:35 PM
» Replies: 39
2011 B9 radio change possibility
09-11-2024 10:47 AM
Headlight removal
08-11-2024 04:45 PM
Cold Start Valve
Last Post: Jehu40
08-11-2024 03:29 PM
Last Post: oldbury863
07-11-2024 07:47 PM
» Replies: 31
M49 Brake caliper carrier
07-11-2024 07:34 PM
