Threads: 68
Thanks Received: 26 in 22 posts
Thanks Given: 22
Hello everyone..
I have had my van for 60k miles now and I look after it. Recently though no amount of lube will free up the hinges on the back doors. Is this a common problem ? I am assuming the only fix is to replace the hinges ??
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
Hi , yes its a common problem if you don't regularly lubricate the hinges. They get all the muck and water off the road spray.
Plenty of wd40 type stuff, leave them to soak overnight and then swing the doors back and forward a lot and it will eventually free the hinges off. Try it with the opening restrictor off.
Do it gently at first so as not to strain the hinge mounting on the door frames. You could try some heat (quicker) but it will burn the paintwork
Threads: 68
Thanks Given: 22
Hiya broadfather11.
What you suggest is what I have been doing and the door has been lovely up 'till now but the last couple of weeks no amount of lube seems to free off the hinges.. I have noticed some rust coming out when I plaster the hinge with penetrating oil but within a day or two the door is stiff again. I am worried the hinge is not recoverable
Threads: 7
Thanks Received: 29 in 25 posts
Thanks Given: 42
4
Try "3-In-1 plus PTFE" oil
Mar 2002 Berlingo Multispace Forte 1.9D 166,000 miles
Threads: 68
Thanks Given: 22
Just an update.... I have been spraying WD Everytime I open the doors and after 3 weeks of 12-15 openings a day the hinges are freeing off.. lets hope they free off before they break off..
Threads: 6
Thanks Received: 10 in 7 posts
Wouldn't grease be better?
Threads: 43
Thanks Given: 137
33
Once its freed off you'll need some lubricant that will stay in the hinge, I came across a can of graphite spray , it will stay in the hinge where wd40 will run out after freeing off the tightness. Or as ddb says try oil with ptfe in it.
Threads: 20
Thanks Given: 2,126
18
Now they're free use motorcycle chain lube.It penetrates before it sets as a grease.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• ddb
Threads: 68
Thanks Given: 22
Thanks for your help. I will stick to chain lube I think..
Threads: 7
Thanks Given: 42
4
(25-04-2015, 08:50 PM)ron Wrote: Now they're free use motorcycle chain lube.It penetrates before it sets as a grease.
Good call, haven't used that for over 10 years but it is really good on things like this.
