1.6Hdi - Oil warning and stop lights flashing
Hi all.
Can anybody help with this:
1.6Hdi Berlingo 2007.
Oil warning and stop lights flash as well as beeping intermittently when in motion - mostly when going up hill or general changes of momentum.
I had the oil sensor changed which fixed the problem for 4 months but then it came back. The oil pressure has been checked and is ok. There are no error codes. Have had the oil changed and oil filter changed and the filter in the sump changed. There is no sludgy build-up in the sump.
I am now 170 quid down and pretty peeved.
Any help would be greatly appreciated...
Thanks,
Jon
Hi try raising front of van off ground and top up brake fluid , has same issue on one but u have to raise front to get a tilt on reservoir . May be ur issue very common .
(16-04-2015, 03:53 PM)hartjon Wrote:  Hi all.
Thanks,
Jon
[-] The following 1 user says Thank You to denisg1973 for this post:
  • whitebus
Thanks for your reply. I can see how it may cause the stop light but could the brake fluid be responsible for the Oil warning light too?
(16-04-2015, 04:49 PM)hartjon Wrote:  Thanks for your reply. I can see how it may cause the stop light but could the brake fluid light be responsible for the Oil warning light too?
If the oil circuit is in order it's likely to be a wiring or electrical connection fault.
[-] The following 1 user says Thank You to Solent for this post:
  • whitebus
Hi Denis,
You replied with a blank message...?
Last Post: ADarkDividedGem
Yesterday 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
