Both Brake Lights Not Working
I would appreciate some advice. MOT is fast approaching and knew I needed to change one of the bulbs on my brake lights. Then realized both brakes lights were not working. I changed both of the bulbs yesterday and the brake lights are still not working. All the other lights are working. Could a fuse of gone or is it a wiring issue? I have a berlingo van 2004.
Fuse, bad earth or possibly the switch.
Thanks for the reply. Is the switch expensive to replace.
about £5 off ebay http://www.ebay.co.uk/itm/like/300886240...108&ff19=0 double check yours before you buy, could be connector come off
Sorry for all the questions, if it is the fuse that has blown,would anything else of stopped working, or is the fuse just for the brake lights
I think fuse (10A F5?) is unique to brakelights assuming the engine bay fuse (50A F12?) hasn't gone, find the switch, short out the connector and see if lights come on - with ignition on!
Separate earths for each light so probably not an earth fault,
Mar 2002 Berlingo Multispace Forte 1.9D 166,000 miles
Thought I would report back. It was the switch that needed replacing. Thanks for the advice.
[-] The following 1 user says Thank You to Berlingo_1999 for this post:
  • ddb
Eolys replacement tank
Last Post: Harrythephot
14-08-2026 12:02 PM
14-08-2026 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
