  • 1 Vote(s) - 2 Average
Limiter fitted
Hi all Iv a 2010 berlingo with a speed limiter fitted Iv had it into citreon and they pluged there machine into my ecu to remove it but there is nothing there There defernatly is one fitted somewhere but they have no idea at citreon any help please 65 mph is too slow
It's the hdi 1.6 90 hp model
Do you know who owned the van before it sounds like an aftermarket fit, I would give the previous owner a ring for any info they may have. They usually hide little black boxes and alarm modules up under the dash/ behind glove box or behind the speedo binnacle.
  • Robert Newton
Hi it was from lex auto lease I rang them they said it was a factory fit one that's why I took it to citreon to remove but no joy and they had no idea either
Hi they usually fit them behind passenger glove box , all u do is snip off the wires and it won't control the speed of van or u can also get phone number off unit and they can reprogrammed to higher or lower speeds , I've removed some from blue gas vans we purchased in bca auctions
(21-04-2015, 05:14 AM)Robert Newton Wrote:  Hi it was from lex auto lease  I rang them they said it was a factory fit one that's why I took it to citreon to remove  but no joy  and they had no idea either
[-] The following 1 user says Thank You to denisg1973 for this post:
  • Robert Newton
Hi thankyou I'll take a look behind there what does it look like
(23-04-2015, 04:22 AM)Robert Newton Wrote:  Usually black be tape on wires they joined in to once removed it be full speed again I have some in garage I'll take pics and put on post for u if u can't find it Hi thankyou I'll take a look behind there  what does it look like
  • Robert Newton
Thanks I'll see if I can find it
Hi Iv found a black box with ramatic dbw system on it Iv opened the box wasn't sure what to cut so Iv pulled the fuse out the van seams to still work just needs testing fingers crossed
(25-04-2015, 01:43 PM)Robert Newton Wrote:  Hi Iv found a black box with ramatic dbw system on it Iv opened the box wasn't sure what to cut so Iv pulled the fuse out the van seams to still work just needs testing fingers crossed
It's a Romatic system on google. If it's the Romatic 80 and you try to tamper with it it reduces the speed to 80% limp mode.
Last Post: BigVtwin996
Today 08:25 PM
Ahh bless them...
Yesterday 04:54 PM
Yesterday 04:45 PM
Last Post: stu76
Yesterday 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
