[Tires & Wheels] Rattling rear!
Has anyone had a rattling spare wheel carrier?
I'm tempted to jam in some form of bung unless someone has a more elegant solution?
Thanks.
2011 XTR 90
Interesting question, I've got a rattle on one (2009 XTR) that just sounds like spare wheel rattle but (non-citroen) garage insisted it isn't but couldn't find what it was , Citroen said noise it was a "feature" and nothing to worry about.
If you know it is spare wheel rattle then I will be having a look myself.
Mar 2002 Berlingo Multispace Forte 1.9D 166,000 miles
(19-04-2015, 07:44 PM)JT1 Wrote:  Has anyone had a rattling spare wheel carrier?
Thanks.
2011 XTR 90
Plastic ratchet clips work a treat
Thanks polar. Plastic ratchet clips? Not sure what you mean exactly, would cable ties be a decent subsitiute?
ddb, yes definitely the tyre carrier, confirmed by local (independent) garage; not serious apparently just annoying!
[-] The following 1 user says Thank You to JT1 for this post:
  • ddb
Where abouts does it rattle from?
2014 Berlingo Multispace 1.6 e-Hdi XTR ETG6
Try removing the unit entirely to eliminate it.
(20-04-2015, 08:55 AM)JT1 Wrote:  Thanks polar. Plastic ratchet clips? Not sure what you mean exactly, would cable ties be a decent subsitiute?
Yes ratchet clips are cable ties by another name.
  • JT1
Great thanks, I'll get underneath tomorrow and try it - thanks for the tip.
Mine came with such a rattle. The cause? The spare wheel had the wrong sized tyre fitted and the looseness was causing the cage to sway. Someone had actually padded out the space with rolled up rubber mats instead of just fitting the correct tyre... Just typical of the kind of nonsense you find whenever you buy a used car and one of the reasons I try not to do it too often! Smile
____
2010 B9 Multispace VTR 1.6 Petrol 90hp
(20-04-2015, 08:51 PM)rm008 Wrote:  Mine came with such a rattle. The cause? The spare wheel had the wrong sized tyre fitted and the looseness was causing the cage to sway. Someone had actually padded out the space with rolled up rubber mats instead of just fitting the correct tyre... Just typical of the kind of nonsense you find whenever you buy a used car and one of the reasons I try not to do it too often! Smile
Interesting. Do you by any chance happen to know what size the spare should be, I'm presuming the same as the other four? From a quick glance underneath it's a steel wheel as opposed to alloy so that could well be the cause. Annoying Angry for you but at least you found the source Smile
First cold startup metallic noise.
Yesterday 09:57 PM
New Van - 2017 B9 BlueHDi build
Last Post: sciteacher
Yesterday 04:35 PM
» Replies: 39
2011 B9 radio change possibility
09-11-2024 10:47 AM
Headlight removal
08-11-2024 04:45 PM
Cold Start Valve
Last Post: Jehu40
08-11-2024 03:29 PM
Last Post: oldbury863
07-11-2024 07:47 PM
» Replies: 31
M49 Brake caliper carrier
07-11-2024 07:34 PM
Peugeot 208 alloy wheels
07-11-2024 07:15 PM
Last Post: dougienisbet
05-11-2024 04:06 PM
05-11-2024 02:04 PM
