gear linkage
my gear stick is getting a bit floppy,i am thinking the linkage is getting a bit worn???is it much of a task to replace them,or would it be best to leave it to someone who knows what they are doing ??? Undecided Undecided your advice please many thanks MY MUCKER
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
What engine ?
On 1.9d they were nylon and wore . I chopped mine out when i did the clutch - interestingly the replacements from pug ( went to pug for main shaft seal , linkage and clutch cable) were alloy and a much more solid fit.
They just pop on and off balls.
Was well worth doing and iirc less than 20quid for the pair.
thanx a lot my mucker,ye its a 1.9d,as a matter of fact i had clutch replaced yesterday and asked for linkage to be done same time,he said it didnt need doing to keep bill down,i got no prob with it ,but it is floppy and the wife wont drive it because of the floppiness.so what is it that needs replacing ??the rods or the balls, or do they all come in the kit??
Thanks My mucker
Hi there if you have a look at this link you can see the parts that make up the linkage http://www.ebay.co.uk/itm/Genuine-Citroe...2a4f95ad94
And these are the parts that usually wear out and need replacing http://www.ebay.co.uk/itm/CITROEN-BERLIN...1e8a388b75
Its quite an easy job to do just need to get the car up on ramps for good access.
If you have a look first you will see the slop in the ball and socket joints that is probably giving you the vague gear change and know which parts you need.
I replaced the long one on my nieces' Partner 2.0hdi. The old one was a bit of a pain to remove but it came off with a bit of brute force and ignorance. The new one just sat in place then pulled down and clicked on easily.
Hiya, I have replaced the three rods, BE4R gearbox, but the one to look out for is the larger Ball on the bracket and the bracket wobbles on the spindle. I'm not sure if the bushes can be changed so be prepared to replace the bracket complete. Also the rod that goes back from the gear selector to the bottom of the gearstick is connected to the gearstick with a bolt, this needed to be checked / tightened or replaced. I have put some washers in mine to take up some slack..
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
thank you all very much indeed, i am much obliged,bit of a stupid Q it has to be in neutral while doing the job ye???
Yes,neutral is right.
I tried to change mine at the weekend and had a nightmare - easy enough to get them off and access wasn't too bad, 1.6HDi - I could do it from the top of the engine bay with the air intake and filter box removed. It was the linkages I bought which were the problem, they didn't pop on like the originals - I needed to remove a pin on each end (needle thickness) and re-insert at arms length with grease on my fingers, by touch alone  - impossible. Managed one with a lot of cursing.
So, a bit of advice........avoid these....waste of money
http://www.ebay.co.uk/itm/CITROEN-BERLIN...0405&rt=nc
are the TOPRAN branded ones ok? It seems that the suggestion is the pack of three linkages but also the arm too with the enormous ball on. I've only looked at mine in dark, but the ball was loose! So not sure is that is a result of something else failing, or not...
One thing after another
Today 10:56 AM
Today 08:44 AM
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
