Threads: 22
Thanks Received: 36 in 31 posts
Thanks Given: 8
Well that's a new clutch fitted and new disks and pads on the front.
£120 well spent.????.
Malcolm.
2001 1.9D Multispace.
Threads: 68
Thanks Received: 26 in 22 posts
Thanks Given: 22
When you changed the clutch did you change the clutch arm and bearing guide ? Which clutch did you buy ? Where did you get the parts from ?
Black Hyundai i30 1.6CRDI 2011
Silver 1.9D Mutispace desire 2004 DW8B non Turbo..
White 1.9D Van 2005 DW8B non turbo..
Silver MGF 1.8 16v 1999
Threads: 22
Thanks Given: 8
(25-04-2015, 10:00 PM)Jed Clampit Wrote: Good price top work two week's you were not in a rush then after work and week end's
I replaced the clutch in a couple of days the week after Easter weekend and replaced the brakes yesterday . Had to take existing off to check height as there are two to choose from.
Malcolm.
Threads: 22
Thanks Given: 8
(25-04-2015, 10:45 PM)ajcommercial Wrote: When you changed the clutch did you change the clutch arm and bearing guide ? Which clutch did you buy ? Where did you get the parts from ?
Arm and guides where OK. Just cleaned them and applied plenty of copper grease.
Clutch kit was Valeo, which was the original one in the car being replaced. Release bearing had disintegrated.
Got the kit from Eurocar Parts.
Most difficult part of the job where releasing the lower suspension ball joints. Big long bar strapped under the arm and plenty of leverage sorted them.
Malcolm.
