Mystery Connector - 1.4 Berlingo
I've been poking around under the bonnet, and happened across this connector.  Does anyone know what it's for?
 I can't find anywhere for it to plug in to, and it's not long enough to reach very far.  Everything seems to be working, although it idles poorly - just wondered if I needed it?
 Many thanks,
[Image: Connector%202_zpsjzmfuydl.jpg]
[Image: Connector%201_zpstdoacrgz.jpg]
I think it's a low level brake fluid warning switch wiring not used on your speck model
You need to clean those leave's from the bottom of you wind screen or you will get water ingress in to the electric's
  • whitebus
Do you have a tree growing in your engine bay?
Thanks Jed - and I will get cleaning
Jonnie - there's all sorts of things growing in this van. It gets thoroughly abused. I expect that the Natural History Museum will want to take a look one day!
Is that not the brake fluid sensor/wiring attached to the master cylinder in the first picture ???? I have the same redundant connector in my 2008 1.4.Take the scuttle off and unblock the drain holes that run down to the bottom off each wing by the A pillar, and its worth poking all the crap out that will have built up there to.
Yesterday 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
