29-04-2015, 06:24 PM
Just replaced the passenger lower wishbone arm as ball joint was shot. I noticed oil leak coming from drive shaft to gearbox end last week so ordered a new one which I fitted at same time. Today I notice oil is still dripping from the seal, it's not residual oil from the job as I have cleaned up area a few times today and still drips after driving.
The old seal was different, it had a rotating toothed wheel pressed into one side, the new one didn't but it is supposed to be correct for my car. Should the seal have this toothed wheel? Also, the old seal had the toothed wheel side fitted facing the gearbox end, is that how it is supposed to be?
