  • 14 Vote(s) - 3.21 Average
dw8 cutting out
evening all can anybody help with this problem, my 1.9 dw8 started to intermittently tick over at 1200 revs and hold back now it cuts out and is a pig to start and is not drivable i have replaced the fuel and air filters this started after i replaced the clutch i can see no leads off any thoughts thanks smithy ps i may take it down to north london and leave it there let the chaves torch it .:censored:
(11-08-2011, 05:59 PM)smithy Wrote:  evening all can anybody help with this problem, my 1.9 dw8 started to intermittently tick over at 1200 revs and hold back now it cuts out and is a pig to start and is not drivable i have replaced the fuel and air filters this started after i replaced the clutch i can see no leads off any thoughts thanks smithy ps i may take it down to north london and leave it there let the chaves torch it .:censored:
Did you bleed cooling system after clutch change ?
no i did not disturb the system, thanks for the reply
(11-08-2011, 06:30 PM)smithy Wrote:  no i did not disturb the system, thanks for the reply
High tick over could be thermostat knaffed, there is also a coolant temperature sensor located in thermostat housing for use in preheating and EGR control systems.
[-] The following 1 user says Thank You to BlueBlingo for this post:
  • smithy
cheers i will have a look at that, will keep you posted, smithy
update. I removed cleaned and refitted all the pump connections and disconnected the battery and did the same to the ecu and it seems to have done the trick all runs ok now
[-] The following 1 user says Thank You to smithy for this post:
  • RJBingham
Non start , turns over
Yesterday 12:20 PM
Looking for breakers with Petrol M59
Yesterday 10:29 AM
MyCitroen App
Last Post: Blakey
Yesterday 08:01 AM
Whats the S for? 19oC/19oC S
Last Post: Hughzie
26-05-2024 04:33 PM
What does a service consist of ?
Last Post: StarFish
26-05-2024 01:46 PM
Ad blue use age
Last Post: curlywurly1971
26-05-2024 08:46 AM
Air con re gas
25-05-2024 06:24 PM
Free undertray for 2011 multispace
Last Post: needsmust
25-05-2024 10:44 AM
25-05-2024 09:49 AM
99bhp & 128bhp same engine?
24-05-2024 09:42 PM
