Threads: 9
Thanks Received: 1 in 1 posts
Thanks Given: 6
Hi guys,my hooter stopped working last few days,it was a bit on and off but has now stopped,checked fuses,any other tips?,my dad has to replace a copper band on his to repair the hooter,is this an issue?
Thanks Given: 188
23
Its the earth connection under the airbag on the steering wheel, Its common have a search on the forum there is plenty of how to repair it.
Are we there yet?????
Threads: 9
Thanks Given: 6
Good man,thank you for the guidance.Top stuff
Threads: 9
Thanks Given: 6
Thanks mate
Threads: 9
Thanks Given: 6
If you disconnect the battery for 20 min,does it ensure the airbag not going off?
Thanks Given: 188
23
Yes it does but just be careful. To get the airbag off there is 3 holes in the back of the wheel that you put a thin screwdriver in an flick the tensioned spring to release. When you have finished make sure everything is switched off including the interior lights then connect the battery you don't get any strange electrical issues.
• kierc0857
Thanks Given: 188
23
You want the thin black wire pushed in a square hole in the steering wheel centre. It would of been a tight fit originally but over time it gets slack a crap design really. To check the earth try running a wire from it to a good earth say the door stay.
