12-05-2015, 10:52 AM
Hi all
As the title suggests the auto adjust clutch cable is breaking my heart and Im hoping someone on here might be able to help.
To make a long story short: Release bearing ate the pressure plate so I replaced clutch, pressure plate and bearing with LUK kit. I also replaced guide sleeve with genuine one from Citroen and bought spurious clutch cable from motor factors and replaced it.
The problem is clutch works fine for approx 100miles then the bite in pedal goes to the floor and its difficult go get it in to gear. To remedy this I pushed back the clutch fork with a long bar until I hear the auto adjuster click. That fixed the problem for another 100 miles and it broke again. I assumed the cable was faulty so replaced with another one supplied from motor factors. The same thing keeps happening.
I checked everything multiple times and all seems ok as its impossible to put clutch facing backwards and also the cable can only be routed the correct way or no way at all as far as I can see.
I talked to a few mechanics and also a Citroen mechanic and there opinion was faulty clutch cable so I got another one. Put it in last night and removed white collar from auto adjuster and not bite at all. Clearly im doing something wrong as I cant be that unlucky to get 3 faulty cables but I dont know what to do.
Any help is greatly appreciated...
