Rear beam
I want to lower my 06' van. I fitted coilovers without a hitch, got the offside torsion bar adjusted but the nearside bar just won't budge. I then put the offside torsion bar back in the original position.
I have tried everything! Hub puller, a 10 tonne press but it just bent the arm, heat and ice.
If I'm going to change the beam for one that isn't seized, does it HAVE to be a Berlingo beam? Are 306 beams the same? Convert to rear discs maybe?
2006 Citroen Berlingo 1.9 D - 69 BHP
1994 Renault Clio 1.8 16v - 212 BHP
1993 Renault Clio 1.8 RSi - 110 BHP
"There is no replacement for displacement"
(15-05-2015, 01:22 PM)til5101 Wrote:  I want to lower my 06' van. I fitted coilovers without a hitch, got the offside torsion bar adjusted but the nearside bar just won't budge. I then put the offside torsion bar back in the original position.
right there matey the beam off a 306 wont fit the only one that will fit is pug 405 so if you were able to get hold of a decent one it would have to be mi 16 would then have discs
good luck
What he said, but the 406 torsion bars are thinner so it will carry less weight and I don't think you need to lower the 406 beam as it is lower to start with.
Rear seat belt breakage
Last Post: Mad one
Today 06:09 PM
Today 05:49 AM
Yesterday 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
