Thanks Given: 1
Thanks very much the problem Iam having at the moment wot happernd is my power streering belt snapped on my way from work in the van I heard sum thing so I pulled up got out and poped bonnet I seen the belt on floor but van wos still running so a got back in and drove it home on battery how ever it cut out as pulled in my street so next day gotit towed to garage by a friend of myn we're I had new belt new starter motor and new battery put on the must of had faults befor belt snapped but still drove fine as used it every day to go to work in sum yellow cum on about engine management but quick turn off then back it whent out but since this happerd the vans never stared since any ideas thank you
Threads: 20
Thanks Received: 13 in 13 posts
Why did the garage put a new starter and battery on when it was just the power steering belt that had snapped?
Threads: 12
Thanks Given: 16
37
What may have happened, is that some of the belt went into the cover, and didn't initially make the cam belt jump, but may have subsequently picked up, and caused this issue.
If your garage guy is any good, he can view live data on a diagnostic tool and look for cam & crank synchronisation on cranking. Personally I would always take the cover off if a belt broke, as this tends to happen a lot, especially if the belt shredded into strips.
