ignition barrel problem
hi guys wandering if anyone here can help me, iv got a berlingo 2003 battery is fine but when i turn the key to start nothing! no lights on dash no ignition not turning over its just dead but the battery is completely fine.
i think it might be an faulty ignition barrel, iv taken all of the cowlings off but i cant seem to find how to remove the ignition barrel cane anyone help any pictures or anything its a 1.9 turbo diesel.
thanks for any help you guys can give
sonny
I didn't know there was a 1.9 turbo (possibly showing my ignorance, asking out of curiosity).
Have you checked the BIG fuses under the bonnet?
Mar 2002 Berlingo Multispace Forte 1.9D 166,000 miles
Well its a family members van he asked me to take a look as why no power, well i checked all fuses there is power going to the barrel but not out to ignition/starter but if i direct power the outputs it will start and run.
Untill the direct power is taken away but cannot understand how to remove the barrel
Thanks ddb
The steering lock ignition barrel are usually held in with an anti tamper screw that you need to centre punch and drill out. Then you need to have the key in the ignition and turn to between marks A and M I think. Then there is a lug you need to push with a screwdriver to release the lock assembly. Don't forget to unclip all the wiring and immobiliser receiver before removing the barrel.
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
