  • 11 Vote(s) - 2.64 Average
Can't go to battery safe mode.
Hi guys!
I have a serious problem, I have a Blaupunkt Mp47, and it's wired with the original cable.
Problem is that, when the car want to go to battery safe mode, the BSI(in the car) give a "click" sound, but's it's "clicking" again, and the consumption is again about 500-600mA.
I noticed, when I disconnect the headunit (pull down the cable) the BSI can go to battery safe mode!
I measured it whit a multimeter.
Please help me!
Can a cable adaptor resolve my problem? Because after I take out the ignition key, the radio turns off about 5 minutes later, and can't turn on again, until I put in ignition.
Sorry for my bad English, and apologize if something is can not be understood.
Thanks,
Andrew from Hungary
You need to wire the switched live to the live to the electric window switch above the radio and run the permanent live to the battery
(13-08-2011, 05:53 PM)corkgsxr Wrote:  You need to wire the switched live to the live to the electric window switch above the radio and run the permanent live to the battery
Sorry, but I don't understand what exactly I need to do.
Disconnect CAN-wire from adapter. May be this will help.
(15-08-2011, 01:38 PM)pk7478 Wrote:  Disconnect CAN-wire from adapter. May be this will help.
From the BSI? What's cable is it?
Yesterday 05:50 PM
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
