  • 20 Vote(s) - 1.8 Average
airbag light sometimes on.?.
hi, my airbag light comes on the dashboard on my 99 berlingo van every now and then when starting the van up .. is there a connector needs cleaning or something.?. thanks
(13-08-2011, 06:21 PM)sniper Wrote:  hi, my airbag light comes on the dashboard on my 99 berlingo van every now and then when starting the van up .. is there a connector needs cleaning or something.?. thanks
just wigel the thin wires under the seats .donot disconect without taking car battery off for 10 mins or airbags may go off lots of pane and lots of £££££
cheers ill give it a go..Big Grin
hi, ive wiggled the wire under the drivers seat and it has'nt made a difference.. thanks.
(15-08-2011, 09:47 AM)sniper Wrote:  hi, ive wiggled the wire under the drivers seat and it has'nt made a difference.. thanks.
Try the one under the passenger side as well...
Suppose, connector in a steering wheel may cause a problem.
Mine is on quite often as my wife always moves the seat.
Just move the seat and then pop it back into position and make sure it's securely clicked into place. Then start the car. Repeat if needed and it should sense the seat is correctly locked into place.
Also try some wd40 on the wiring and runners under the seat. Tends to stop it happening quite so easily.
Is it on all the time or on then off?
Mine became intermittent at first, then became more frequent until it stayed on for ever.
On my van it was the ribbon cable in the COM 2000 unit that had broke where it plugs into the airbag plug.
Changed the COM unit for a new one and sorted. Cost 124 quid brand new Valeo part
From next year it is going to be an MOT fail if the air-bag light is on.
I have had the same problem on and off over 2-3 years. It happens when my wife forgets and hides her handbag or notes under the seat if calling at a clients home. I used to be able to wiggle the wires as noted above but last time it didn't help. This time I did some more smoothing of the wires and disconnected and reconnected the little brown plug under the seats and it worked a treat. Nothing since and my wife is aware now not to stick things under the seat or at least be careful. I didn't know about the need to isolate the battery before unclipping the connector as mentioned above by Ian. I will follow that wise advice next time as it makes sense, but I clearly got away with it this time without the airbags blowing. I had assumed that the circuit is ignition key controlled.
Newbie
Last Post: DannyWxM
Yesterday 07:39 PM
Thermostat Overheating, Radiator Cool
Yesterday 07:34 PM
Oil consumption at 200K miles
22-05-2025 12:47 PM
21-05-2025 06:54 AM
20-05-2025 09:42 AM
» Replies: 54
Last Post: rnamman
19-05-2025 02:03 PM
Last Post: allanr
18-05-2025 05:57 PM
Forum activity
17-05-2025 06:32 AM
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
