key fob
Hi all, my remote key for my berlingo forte 2004 hdi is working but the open button has worn out the rubber has fallen out and is difficult to operate , has anyone rectified this , and can share the info, .
[-] The following 1 user says Thank You to sweetkwan for this post:
  • whitebus
(05-06-2015, 12:46 PM)sweetkwan Wrote:  Hi all, my remote key for my berlingo forte 2004 hdi is working but the open button has worn out the rubber has fallen out and is difficult to operate , has anyone rectified this , and can share the info, .
You can get the plastic shell from eBay for a couple of quid, it includes the shell and the buttons..... you then need to transfer the circuit board and the most importantly the transponder (little block)
HTH
Cheers Manuk, much appreciated will take a look.
I bought a new key (blank blade and shell) on ebay for about £3. Local motor factors charged £10 to cut new blade, fit 2 new micro switches to circuit board and fit to new key.
[-] The following 1 user says Thank You to jonnie100 for this post:
  • whitebus
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
