[Transmission] clutch cable
My clutch pedal has dropped to about two inches off the floor - still driveable but a bit crunchy sometimes. Haven't had a chance to look yet but I'm guessing the cable adjuster is gubbed? Haynes manual makes replacement sound straightforward but thought I would check here for any tips. Is oem cable the best bet?
It's a 2002 2.0hdi.
OK job done. Bought a genuine Citroen one from AEP. Most difficult bit was threading it through the hole in the bulkhead - I could do with growing a longer thinner arm. All connected up and I tried it and it was just the same as before. Sat there pumping the pedal wondering what I had done wrong and eventually it self-adjusts but only after several minutes. Now smoother than it has ever been.
Glad you got it sorted let's hope it last another 13 year's  Smile
Last Post: ADarkDividedGem
Yesterday 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
