Radio illumination stays on
I've a 2004 2.0HDI which I've owned from new, and I've clocked up nearly 250,000 reasonably trouble free miles. Shortly after I bought it, I replaced the radio with a pioneer unit, but I kept the original for that time when the van would be sold - which is now. I've refitted the original radio using the existing harness, and programmed it in using Lexia. Everything works including the MFD, but - the radio illumination (buttons and the CD insert guide) STAYS on! I didn't notice this at first, but I knew that something was wrong when I connected up the radio that night, and then the battery was flat the next morning.
There's a illumination table in the radio programming options on Lexia, does anyone know if this would have something to do with it? I just left everything on the default setting when running the programming sequence.
When you put the pioneer radio in originally did you swap any wires round in the connector block to make the pioneer work? If so have you changed them back as it sounds like you have wires crossed. You shouldn't need lexia to refit the radio it should just plug in.
Nope, I left the original connector on the loom, and none of the wires were cut or changed. The radio had been disconnected for around 10 years, and wouldn't do anything when I plugged it back in. I ran Lexia, programmed it (it automatically came up with the correct vin number) and everything worked fine - apart from the illumination being constantly lit.
TBH the radio's illumination by itself should not flatten a healthy battery.
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
