  • 19 Vote(s) - 2.95 Average
replace 99 blingo van 1.9d fuel filter
hi, is it hard to replace a diesel fuel filter on a 99 blingo van dw8.?. i have bought filter just need to know if theres any tips/problems with the job.?. thankyou.
Did my 98 Blingo last year. Only problem was the amount of bleeding at the filter and Lucas injector pump nipples I had to do after fitting the filter. Even although the air bubbles had stopped I had to keep bleeding until the sodding thing started. Thank goodness for the rubber priming bulb thing. Good luck!
Tony L
Hi Tony L If your fuel filter housing is like my 2002 model and I think it is, it's easy to change.
Make sure you put a rag under the filter housing to catch any spillage. Put a bit of rubber tube on the drain cock on the bottom of the housing and drain out fuel. Undo the cover clip and remove old filter. Clean inside the housing with a bit of kitchen roll. Install new filter and pump fuel in with cover still removed until up to level. Replace cover and with great care replace fastening clip, be gentle, I broke mine and had to fix it on with a large hoseclip.
Mine has a plastic button on the side of the filter housing as the primer pump, with the cover on pump away and get an assistant to start the vehicle, you will hear electric fuel pump clicking away, with the engine cranking keep pumping and it should fire up and keep running..... good luck.
Pappy
Hi,
on my M49 DW8 i did the following
1) unclip filter housing lid
2) remove old filter
3) place new o rings onto new filter -
4) Fit new filter into housing
5) clip back in place
6) press priming pump lots of times
7) start van and hold a *light* throttle - if it cuts out then repeat step 6 until successful
may not be entirely factory procedure but it works for me Smile
..i chickened out and got the local mechanic to put a diesel filter on for me ...thanks....
Last Post: Grizz
Yesterday 10:49 PM
» Replies: 687
One brake light working
Last Post: dumdum
Yesterday 11:36 AM
Rear Hub Nut Size
Last Post: ntm1275
24-03-2019 11:06 PM
Engine noise
Last Post: cancunia
24-03-2019 05:01 PM
» Replies: 31
Cruise control (again), yes again, but working (...
Last Post: cancunia
23-03-2019 01:24 PM
» Replies: 101
2003 2.0 HDI Poor fuel consumption
Last Post: Trevor
23-03-2019 12:38 PM
» Replies: 34
puff of blue-ish smoke on startup
Last Post: Art b
22-03-2019 10:37 PM
Speedo / Instrument Cluster Removal
Last Post: cancunia
22-03-2019 04:05 PM
airbag stolen - is it a thing
Last Post: rapidyellow
22-03-2019 10:39 AM
EGR valve
Last Post: cancunia
22-03-2019 10:19 AM
