Threads: 2
Thanks Given: 2
Hello all
Just replaced head gasket (was like a soggy cheese toasty), timing belt, coil pack, plugs and thermostat on above mentioned beasty (a character building experience!). Starts, idles nicely but give it a whiff of accelerator and either it stalls the engine or there is no power.
Anyone got any ideas? I've got no access to any fault scanning trickery so can't check for fault codes.
Thanks in advance
Threads: 17
Thanks Received: 40 in 32 posts
Thanks Given: 6
Sounds like fuel/mixture problem to me. Is everything connected ok on the inlet side -no air intake leaks? When was the fule filter last changed (Although I would expect that to affect starting too)
Griff
Landmark
Ex 1.4 Berlingo Multispace
The following 1 user says Thank You to Landmark for this post:1 user says Thank You to Landmark for this post
• Bumpkin
Threads: 2
Thanks Given: 2
Thanks for the reply Landmark.
Inlet manifold was torqued gently and injectors are all snug. No idea about the fuel filter (where is it?) but probably should replace given that it's only a few quid.
Threads: 23
Thanks Given: 50
29
Check the throttle body is working and all the wire's going to the sensor's it seam's air is getting in with no fuel also look at the MAF
Threads: 23
Thanks Given: 50
29
14-06-2015, 10:33 AM
(This post was last modified: 22-06-2015, 09:08 PM by Jed Clampit.)
Good old carb's those were the day's it's the meter on the inlet pipe
Threads: 2
Thanks Given: 2
MAP sensor ordered, also a throttle position sensor (a bar steward to find and a lot of pocket money). Will update when I get the parts fitted.
When do you stop when you're gilding a turd?
Threads: 2
Thanks Given: 2
UPDATE!
I swopped out the MAP sensor on the inlet manifold and the potentiometer on the throttle body. Runs smooth!
