big Hi guys
Hi fellas just picked up a 2012 berlingo enterprise, seems quite torquey but ill get it remapped, plus im going to stick some alloys on ive got a set of 18s the question is will they fit lol cheers lads Smile
Hello bigchiefkeef welcome to the forum good to have you with us   Smile  will they won't they what have they come off four stud five stud off set spacer's and so on more info please  Smile
the wheels are off my mrs 2004 mini cooper they are 8x 18 with 225x35x18 i know the pcd is different so im unsure wether to get the wheels redrilled or use some hubcentric spacers which i can change the pcd that way, the smallest hubcentric spacer is 20mm
the mini cooper pcd, is 100, offset is 45, center bore is 56.1
the berlingo pcd is 108 offset is 26 center bore is 65.1
so by my reckoning, ill get the hubcenric spacers at 20mm which will take up the difference on the offset, and change the pcd to fit, plus get the center bore to suit, the only difference then will be the extra width on the rims of 30mm should take the in line with the arch, how does that sound to you Jed?
16-08-2026 08:18 AM
16-08-2026 07:56 AM
Eolys replacement tank
Last Post: Harrythephot
14-08-2026 12:02 PM
14-08-2026 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
Strange whining noise
05-08-2026 04:28 PM
