Will 18s fit
Guys ive a set of 8x18s with a 28 offset, now my question is will they fit, these have come off my mrs mini cooper 2004 and ill need to put a spacer with the pcd changed to suit my Berlingo, ill have a measure up and test fit, but has anyone got a set on?
The berlingo 15 to 27 off set 108 x 4 you mite need spigot ring's or the centre's mite be to small try to fit them to see what your up against  Smile
no, mini pcd is 4x100 im afraid
the mini cooper pcd, is 100, offset is 45, center bore is 56.1
the berlingo pcd is 108 offset is 26 center bore is 65.1
so by my reckoning, ill get the hubcenric spacers at 20mm which will take up the difference on the offset, and change the pcd to fit, plus get the center bore to suit, the only difference then will be the extra width on the rims of 30mm should take the in line with the arch, how does that sound to you guys?
finny what wheels and size have you got mate, they look sweet, and where and how much lol cheers mate
mine are 18" c4 Picasso krakatoas, come up on ebay every now and then, how about a set of these? http://www.ebay.co.uk/itm/4-neue-Alu-OZ-...259ffb1599
Iceland Trip and modifications
Today 05:49 PM
Rear disk wear
Last Post: Antdad
Today 04:30 PM
Today 01:55 PM
Sliding door moulding part number
Last Post: Cbalchin94
Today 11:29 AM
ABS Sensor Fault M59 1.6HDI
Last Post: Antdad
Yesterday 02:46 PM
Intermittent starting
Last Post: HenryD
Yesterday 09:22 AM
2024 facelifts Berlingo vs Combo Life
Yesterday 07:09 AM
Engine judder at 1800 rpm
Yesterday 07:06 AM
What is this?
15-09-2024 07:13 AM
service light(spanner) keeps coming on after res...
15-09-2024 07:07 AM
