Threads: 23
Thanks Given: 50
29
Hello jbhleopard welcome to the forum you could block the end's of the vacuum pipe'off stop the egr working or put a blacking plate in front of the egr you should not have any problem's with the egr
Threads: 3
Thanks Received: 1 in 1 posts
Thank you for your advice.
I shall give it a go, just one thing - how do I blank off the egr end?
Thanks again
James
Threads: 10
Thanks Received: 4 in 2 posts
Thanks Given: 1
im new to berlingos having had transit mk5 minibus alas until recently the blacking off was the same as what you have done but you tied the butterfly open on the intake manafold have search all forums relating to the dm8 engine and they talk of putting a bolt into a vacume pipe its this related to dm8 or hdi engines
Threads: 43
Thanks Received: 412 in 369 posts
Thanks Given: 137
33
19-06-2015, 03:37 PM
(This post was last modified: 19-06-2015, 03:40 PM by brodfather11.)
Hi Jimmy,
its the dw8 engine you mean and yes you're better with some way to keep the flap open as the vacuum opens it and then block off the vacuum pipe. Not sure if it applies to the 1.6 and 2. hdi engines.
No vacuum = flap shut.
Threads: 10
Thanks Given: 1
thanks for that information
