Threads: 2
17-06-2015, 05:59 PM
Hi all, I have a 05 1.9. Recently the electric windows stopped working. I have checked the fuse, the wires at the door opening and changed the relay(green box under the fuses) and all seem to be in order. Does anyone have any ideas what Ive missed, or what to check next ?, thanks in advance. Oh and I posted the same problem in how to and don't know how to remove it, sorry.
Thanks Given: 188
23
Have you checked the engine bay fuse box look at F9 its an 50A fuse this goes to the BSI and on there should be a 30A fuse. Check for power at each output side of the fuses. Can you feel or hear the relay clicking, check for power coming out of the relay.
Are we there yet?????
Threads: 2
F9 in engine bay fuses is a 15amp and the table of fuses says its LH dipped beam. The relay isn't clicking. I don't have a multimeter, but ill try get me hands on one. Ive checked all fuses now in the engine compartment and inside. Windows are slightly cracked open, doing me head in.
Threads: 2
No power coming from relay, so cut the wires for the motor and connected a battery up to them to close the windows.
