Threads: 5
Thanks Given: 2
25-06-2015, 07:29 PM
(This post was last modified: 25-06-2015, 07:30 PM by Mehmet Salahi Mehmet.)
As above. 1.6hdi For the love of me i cannot see where its leaking from any common faults with these? Also I changed the thermostat but the temp still goes no higher then 70. Is this normal?! Many thanks
Threads: 25
Thanks Received: 235 in 131 posts
Thanks Given: 44
12
Not enough information.
What liquid leaking? Oil or coolant?
What is outside temperature?
Can you check thermoresistor by yourself?
Threads: 5
Thanks Given: 2
Sorry i did state in the thread title. PAS fluid. Power steering fluid.
the outside temps in the UK are currently 25/32c
where is the thermo resistor? And how do you test these?
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
there was a thread not so long ago about a leak of PAS fluid , I think it was traced to the steering rack pressure pipe O rings.
