  • 19 Vote(s) - 2.37 Average
using new vegtable oil
hi, is it possible to use new vegtable oil to run my 99 berlingo van 1.9d dw8 or would it do the fuel pump no favours.?.. thanks.
It is possible to use diesel fuel in your engine!
Looking around at the prices for new vegetable oil, it hardly seems economically viable to use it in preference to diesel and to also risk damage to fuel injection components
If you have a bosch pump then you should be o.k.....I have ran veg oil mixed with alttle kerosene to make it less viscous on my 96 406 and it ran fine...:-)
Change the diesel filter often and remember the veg oil tends to soften the rubbers seals on the fuel line/ filter seals etc.
Ron.
thanks for replies, its just that i seen in tescos yesterday they have some half price deals on there 5 litre vegtable oil containers.. suppose its not really worth the risk then.. thanks.
I think its more possible with an old Landy or WHY with a slow revving Perkins type diesel.
The modern high speed engines with tight tolerances are much more fragile.
Much better find yourself a source of red diesel !!
'98 D 800 van Big Grin
I used to run my XUD Xantia on new veg oil without any problems, but it was only for two years. Long term it may cause problems.
I used to run kero for off roading, for every 5 gallon I'd add 2 litres of mineral engine oil.
No smoke or probs at all and kero was cheap at the time.
Its got a nippy smell about it when the motor is stationary.
I alway considered running a 50/50 mix of mega filtered cooking oil with cherry or 50 kero with the mineral oil and 50 cooking oil.
2003 Berlingo converted to run a modified xud9te.
Running 24psi of Boost.
2.5" solid pipework and Fmic.
Converted to electric power steering.
Garrett T2
(16-08-2011, 06:54 AM)colinh Wrote:  I think its more possible with an old Landy or WHY with a slow revving Perkins type diesel.
Using red diesel is illegal & can lead to heavy fines & confiscation of vehicle.Rolleyes
Red diesel can still be detected even after it has been used in a vehicle as well.
07-04-2026 04:17 PM
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
