Coolant type
Hi, just checked and my coolant is below low level. I had it changed at Swindon Citroen and seems they must have not bled it correctly. I found the coolant cap was not correctly screwed back on also.
Consulted the manuals and can't find a "type" on citroen specific. I am in Spain and need to source some locally. Any suggestions?
A search turned this up -
Quote:http://www.berlingoforum.co.uk/thread-16...ht=coolant
Also found the PSA - B 71 5110 spec associated with this which may help you source locally.
Look at the second post from pk7478.  Hope this helps.
muy caliente en España, ¿no?
Fuchs Maintain Fricofin LL is PSA B 71 5110 spec. Opie Oils sell it in uk but that probably doesn't help.
If you have a Cit or Pug dealer nr you they should sell ready mixed topup. UK Cit garages do. Look on citroen.es for nearest dealer otherwise, norauto.es like Halfords so should have correct stuff.
Warranty on parts
Yesterday 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
02-08-2026 02:22 PM
Berlingo 2026
Last Post: xtimex
29-07-2026 03:34 AM
