2012 berlingo non start
Hi all
I`m after some help if possible,
I`ve got a 2012 berlingo van 1.6HDI - it has a non start issue.
when the van is left for 5 days or money the battery goes flat.
van is @ dealers now - they have tested & tested & tested and still unable to find drain.
the dark current drain is 0.04 amps.
Has anyone any ideas on what this could be
Cheers
Possible internal short in battery?? Would fully charge, remove from vehicle for five days and then test.
Or easier after a run when you know battery is good, disconnect front lead. If it still won't start after 5days then you know its battery fault.
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
