[Engine] Engine Runs On!!
Hi chaps Havn't been on for a while,My 1.6 hdi has started to run on when you lift off the gas before changing gear,It seems to only happen when the engine is warm!!,Hope i make sense....Any Ideas would be gratefully accepted has its pissing me right off!!
The first thing to check is the throttle body and the throttle body sensor
If the engine stops immediately the key is turned off it shouldn't be the turbo, but keep an eye on the sump level.
Cheers guys,Don't know much about throttle bodies etc,I had a new turbo fitted last year!!,Forgot to mention it has a flat spot between 1st & 2nd don't know if that's related?
Sorry, Yeah it shuts down immediately on the key with no run on at all.
It may pay to have the air flow sensor checked.
Last Post: TGD
Yesterday 09:50 PM
Yesterday 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
Mark 3 camper van conversion
Last Post: minkybeau
23-05-2026 07:38 AM
