Lingo roof boxes
Hi folks,
I am considering looking at getting a roof box for our Betty Berlingo.
Do I need to buy roof bars first to attach the box onto or do they somehow fit onto the bars that run lengthways on the roof?
Many thanks in anrticipation of any replies:o)
(03-07-2015, 08:55 AM)Burt Wrote:  Hi folks,
http://www.roofbox.co.uk/roof-boxes/
Tells you all about them here.  Looks like you have to buy bars across the width to fit the box to.
2001 1.9D Multispace.
[-] The following 1 user says Thank You to malgpz900 for this post:
  • Burt
is a roof box easy to put stough in and get out by standing on side of vehicle
Confused
If your 8 feet tall its easy,if not you will have to use a pair of steps and then stow them in the roof box !! Exclamation
(02-10-2015, 08:34 AM)bikergraham Wrote:  Confused
Or put them in the boot Wink
Here's ours. Halfords Exodus box. Pleased with it. I have Thule bars, but I don't have the Citroen roof rails. If you do, you'd get bars that attach to them
Fitting the damn thing is hard but loading is ok ish standing on the door sills. As you can see I mount mine off centre so I can reach... Also bear in mind height restrictions when driving.
I wouldn't be without it though...
[Image: d16244a07f15338e76bfeca0140d1186.jpg]
...and doofer is right - heavy cases in the boot. I find ours useful for camping tables chairs and sleeping bags - that kind of thing. Basically the stuff that previously was blocking my rear view mirror.
Oh and wait till the Halfords boxes are on offer. They nearly always are. Then they're good value IMO, but the Exodus ones, not the cheaper range...
I use a Thule box on my Berlingo, with Thule cross bars.  It's easy to fit as it has the advantage of being able to open it both sides, so no leaning across to reach the other side fittings.  Being a shortie (5'8") I need a small step ladder to load it safely although I can just about do it standing on the door sills.  It makes packing for our holidays to France a breeze.
2013 Berlingo XTR 1.6 HDi 90 (WAV)
2016 Partner Tepee 1.6 Blue HDI S/S (WAV)
2020 VW Caddy Maxi Life 2.0 TDI (WAV)
Last Post: wbchevron
Today 07:34 AM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
