Battery replacement
Hello,I have a 2014 airdream ehdi stop start which needs a new battery?
When battery is changed does it need to be programmed ?
Or will it program itself after a couple of hours?
New in 2014? I would get it back to the dealer ASAP
[-] The following 2 users say Thank You to Trevor for this post:
  • steveleeds, whitebus
(04-07-2015, 03:06 PM)Trevor Wrote:  New in 2014? I would get it back to the dealer ASAP
Hi I have done 45 k in a year ,used as taxi,so radio sat nav running off it.
Battery only charging up to just over 50%.,even after long runs.
Just need to know if I can change it myself.
You can but have you researched the price of a stop start battery! Remember your warranty is 3 years or 100k
[-] The following 2 users say Thank You to polar for this post:
Hello steveleeds welcome to the forum if you look on the battery there will be a number like 096 or 100 may be higher use this number for a ref for the new battery you need  Smile
IT will program it self
[-] The following 2 users say Thank You to Jed Clampit for this post:
On my last L2 Berlingo van the battery lasted four and a half years and covered 335,000 miles in daily use, Winter and Summer in that period. The problem in your case Steve is the urban use and all that stop start in town, mine was mainly motorway cruising.
[-] The following 2 users say Thank You to CourierJim for this post:
Have you tried the new type of charger that regenerates the battery?
Hi I replaced battery this afternoon.with a Bosch agm type 096.
Everything is working fine.
Start stop is working again.
Smile
Glad you got it sorted happy day's  Smile
  • steveleeds
Don't waste too much time trying to get a new battery out of Citroen after 12 months, despite the implied warranty.
Mine went just after the first year and I got the old "Its a consumable item & not covered" speech.
They "kindly" offered to replace it for me, telling me it could be complicated & dangerous to DIY!
Well, I saved £60 by DIY and it was neither complicated nor dangerous!
I put mine down to just being a rubbish first battery, as the replacement is going strong after 2 years.
Now if you want a challenge, replace one in a 2001 Range Rover without reprogamming the sunroof, all 4 windows, door locks, 2 key fobs, radio and the engine immobiliser..... That taught me to temporarily connect a small 12V battery to the main battery connections before removing the old one and disconnecting after the new one is in place. That way nothing needs doing. So I now do it on all my battery swaps & they're done in a jiffy.
Good judgement comes from experience, and experience comes from bad judgement…
2017 Berlingo Multispace Flair 120
2013 C5 Tourer 2.2HDi Excl
Previously:
2012 C5 Tourer 1.6HDi auto
2012 Berlingo Enterprise 1.6HDi Van
2009 C5 Tourer 2.0D
2001 C5 Tourer 2.0D
2001 Range Rover 4.6 Vogue (really!)
[-] The following 1 user says Thank You to Argos69 for this post:
  • whitebus
Eolys replacement tank
Last Post: Harrythephot
14-08-2026 12:02 PM
14-08-2026 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
