Aftermarket stereo question
Hi, I'm new to this forum so go easy on me if this has be asked a million times.
I have just bought an 08 plate berlingo 1.6 hdi 92bhp. I have a Sony Bluetooth heady it from my previous van which I've tried to fit.
It plugs straight into my connectors but it has a constant live and still continues to play once I've removed the key from the ignition. It will only turn off if I do it manually.
Is this something someone can help me with?
Do I need another connector for it to s**t off once I've removed the key?
I'm not bothered about the display or stalk functions not working.
If someone could post a link to eBay for the right cable that would be great.
in this connector toyr blue device have 3 wires to make it live
one is permamnet power for memory and second one is triger line(on/off) and last one ground
some pepople connecting this together whoat colours you have ther i migh help, with this im quite good Smile im living in london if this will help with no cost i can show you or help.
i connected my one to permamnet live cable from radio to memory cab. other to ground and trigger to my accesory light so as i turk key on my el. windows buttons are light on as remove they off, and my problems gone Smile just link cable to triger cable if i good remember you should have
black - ground
yellow - swich trigger
red - permament
if something write on priv or on here Smile hope this help
Had the exact same problem on Sunday. The thick yellow wire is the switched live, swap it over with the red wire. However my stereo still stays on for exactly 1 min 38 seconds. I have no idea why.
(08-07-2015, 05:27 AM)Mikey Hedison Wrote:  Had the exact same problem on Sunday. The thick yellow wire is the switched live, swap it over with the red wire. However my stereo still stays on for exactly 1 min 38 seconds. I have no idea why.
It stays on becouse you car have safty features to make your battery not drain full it swichin to eco mode to save battery, after that relay is cutting of power from accesories
Ah ok, is it possible to have it turn off with ignition off then Dawid?.
Cheers for your replys. I managed to sort it. You need to swap pins number 4 and 6 around in the stereo end block connecter. Takes 2 seconds and now it's working perfectly.
[-] The following 1 user says Thank You to Steve Wordley for this post:
  • Mikey Hedison
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
