Threads: 29
Thanks Given: 67
20
06-07-2015, 03:58 PM
(This post was last modified: 06-07-2015, 04:01 PM by ffrenchie.)
They should go straight on at that size, as long as the centre is right size. Berlingo are et19 but 1mm won't make much difference.
Threads: 12
Thanks Received: 69 in 55 posts
Thanks Given: 7
early c5/pug 406 alloys, sure someone on here got a set on theirs, just make sure you got the correct genuine bolts
Threads: 3
Thanks Received: 1 in 1 posts
Thanks for the replies lads, got the wheels and they are a very tight fit. Assuming I need the specific Citroen alloys wheel bolts not with the flat head?
Threads: 3
Sorted in the end. Bolts cost more than the wheels though!!
No problem fitting and no rubbing at all, look great too!
The following 1 user says Thank You to AlfaMan for this post:1 user says Thank You to AlfaMan for this post
• ffrenchie
