What's the best cooling system flush you've used
I'm doing a complete flush out on the cooling systems of my mk1 berlingo and haven't yet chosen which flush to use, so I wonder if you can suggest which is the best and why.
My system looks pretty messed up as it looks like its had no anti-freeze and a previous hose leak.
Looking forward to your response.
Prize for the best answer.
Prize draw ends July will be held July 2090 Dodgy
Forte is,I believe,the best.Used it for years in the motor trade with excellent results. Beware it will show up a weak heater matrix.Good luck.
would you need to leave this product in the system for a long period of time with the engine running and thermostat removed
because i cant drive it until ive fixed other items so stationary engine runs only im afraid
oh
thanks for your reply
(09-07-2015, 09:17 AM)petesta Wrote:  would you need to leave this product in the system for a long period of time with the engine running and thermostat  removed
oh
No prob with that.run it to hot,let stand for a while,run to hot again & drain.I used to back flush afterwards in case there was excessive sludge.
Shock Ron we don't want to know about your colonic irrigation  Rolleyes
  • ron
(09-07-2015, 08:58 PM)Jed Clampit Wrote:  Shock Ron we don't want to know about your colonic irrigation  Rolleyes
Sorry that browned you off. Rolleyes
Has long as you don't write a ( thesis ) on it ill' let you off   Wink
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
26-02-2026 07:20 PM
