Alternative radiator hose
I've been searching the net to find radiator hoses for my berlingo mk1 van
So I'm getting back prices of £64 for one hose
No way I'm paying that
So what's to stop me buying a length of radiator hose in the  bore size I need and either re route it so there are no major kinks in it ?
Or to achieve the bends I require , using  plumbing fittings
Like elbows or straight couplings ??
As always
Any feedback  please ???
 Why Not , Smile
                  if it works well and good , If not try something else.
   It wont cost you £64.00 Rolleyes
  • petesta
Thats a good idea petesta I wont be paying 64 squid ether if I need that pipe.
[-] The following 1 user says Thank You to RolyG for this post:
  • petesta
Use the copper plumbing fittings and copper pipe and just use rubber ends, that's what I did on my home made car and lots of others do it.
  • petesta
Thanks for your replies everybody
i have the bits to make this happen so will get around to it after i have looked in to a feww other problems the van has.
What i would really have liked is to have clear heating tubes so that i would be able to see the condition of the coolant and any air bubbles in the system
I must stop over thinking things
otherwise i will be creating a monster Berlingo Idea Idea
[-] The following 1 user says Thank You to petesta for this post:
  • ron
Why not you can get clear reinforced hose  ?  Smile
(09-07-2015, 08:43 PM)Jed Clampit Wrote:  Why not you can get clear reinforced hose  ?  Smile
Also good for CI Big Grin
  • petesta
I did sort out the cooling system in the end.
I purchased some heating rated hose on ebay and re- directed it to its locations from lower radiator to engine block and secured it in to place and im happy to say it works just fine, so £7 instead of the £64 i was quoted for the original hose.
Good stuff
Well done !
  • petesta
http://www.ebay.co.uk/itm/SILICONE-RADIA...Sw3ydVkRNp
Now you know why people buy silicone hoses, it's not a tuning/visual performance thing. It's just they are the only one that make cheap stuff and with the correct bends.
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
