Radio eco-mode
I regularly drop the kids at various 'activities' then have to wait for them. I listen to the radio for 20 minutes then it goes into eco-mode and switches itself off. The only way I can continue listening is to have the engine running, what's eco about that!!
Is there any way of de-activating this mode?
(10-07-2015, 05:59 PM)loftypeak Wrote:  I regularly drop the kids at various 'activities' then have to wait for them. I listen to the radio for 20 minutes then it goes into eco-mode and switches itself off. The only way I can continue listening is to have the engine running, what's eco about that!!
I don't think its possible to disable but I think Lexia can be used to adjust the time.
[-] The following 1 user says Thank You to andyd76 for this post:
  • loftypeak
OK thanks for that, I'll look into that option. Cheers
I looked at this when I first got my 2010 model and using a Lexia there is no option to disable or adjust the time I'm afraid
turn ignition on then off, get another 20 minutes
63 plate Berlingo working hard.....
[-] The following 1 user says Thank You to ATL_driver for this post:
  • ron
On my 2010 model, I have to start the engine to turn off ECO Mode
This is what my user manual says
"After the engine has stopped, with the key in the ignition position, certain functions (windreen wiper, electric windows, courtesy lights, audio equipment, etc.) can only be used for a cumulative duration of thirty minutes, to prevent discharge of battery.
Once the thirty minutes are over, the active functions are put on standby and the battery warning light flashes accompanied by a message on the display.
To resume the use of these functions immediately, start the engine and let it run for a few minutes.
The time available will then be double the time for which the engine was left running. However, this time will always be between five and thirty minutes"
Whatever ... It can be darned annoying.
If you replace radio with after
market unit you can run your battery down to flat .. If your that way inclined...
Sent from my 3geesus using Tapatalk( it's ifail)
will getting a new radio from Halfords stop this eco mode thing turning radio off ?
(26-09-2015, 07:44 PM)whitts99549932 Wrote:  will getting a new radio from Halfords stop this eco mode thing turning radio off ?
Be careful putting an after market radio in. My son's Citroen had a DAB radio fitted by Halfords. When he had to disconnect the battery for some work the clock could not be reset, the MPH was now in KPH and could only be changed with the original headset in place. Be very careful about changing the headset and Halfords are not necessarily the best people to get that information from.
Iceland Trip and modifications
Today 05:49 PM
Rear disk wear
Last Post: Antdad
Today 04:30 PM
Today 01:55 PM
Sliding door moulding part number
Last Post: Cbalchin94
Today 11:29 AM
ABS Sensor Fault M59 1.6HDI
Last Post: Antdad
Yesterday 02:46 PM
Intermittent starting
Last Post: HenryD
Yesterday 09:22 AM
2024 facelifts Berlingo vs Combo Life
Yesterday 07:09 AM
Engine judder at 1800 rpm
Yesterday 07:06 AM
What is this?
15-09-2024 07:13 AM
service light(spanner) keeps coming on after res...
15-09-2024 07:07 AM
