[Steering & Suspension] Suggestions re likely fault.
I recently replaced the discs and pads on my 2.0hdi. No issues with the brakes and there are no steering wobbles or shudders. Braking is smooth and predictable.
However, I have noticed a quite quiet clunk seemingly in the area of the front nearside suspension that is more noticeable when the suspension loads and unloads coming out of a bend and over bumps in the road.
Before I have a poke around, what is the most likely culprit? I was thinking suspension control arm - any other ideas?
Cheers,
David.
[Image: 108137.png]
Do not write below this line. Office use only.
(11-07-2015, 08:16 AM)thurrockdave Wrote:  I recently replaced the discs and pads on my 2.0hdi. No issues with the brakes and there are no steering wobbles or shudders. Braking is smooth and predictable.
Cheers,
David.
Hi David
well the first thing i would do is go over the work area thats be worked on
especially if there was no problem before this work was done.
i recently had new discs and pads and the car developed vibration above 60mph
turned out to be a wheel weight got dislodged during the repair .
Good luck in solving it.
[-] The following 1 user says Thank You to petesta for this post:
  • whitebus
Broken spring?
  • whitebus
Bottom ball joint? Make sure the pinch bolt is nipped up tight enough.
Could be anti-rollbar drop link ?
Rear door filling with water
Yesterday 06:56 PM
MOT Emissions repeated fail
Yesterday 06:53 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
