Electric window trouble!
Hi
I've got a 55 plate 1.9D van.
The drivers side window only works when the accelerator pedal isn't pressed. So either decelerating or parked.
I guessed that this might be an earth problem somewhere but I don't know where to start looking!
I assume this is a rare problem and I would like to save on the garage bills so any advice would be greatly received.
Huh
Checks of BSM(first), PSF and BSI gonna save your bills Smile
Err what?????
See atached file and descr. below.
Suppose this will help you
BSI Built-in systems interface
BSM Engine relay unit
CV00 Switch module at the steering wheel
0004 Instrument panel
1320 Engine ECU
6570 Airbag ECU
7215 multifunction screen
7800 Stability control ECU (ESP)
8080 air conditioning ECU
8410 Radio
8415 Compact disc changer
8500 Navigation ECU
8600 Anti-theft alarm system
Here it shown more clearly in chapter V-1 'Fuses':
http://berlingoforum.co.uk/Citroen%20Ber...ndbook.pdf
.bmp   M59_elec.bmp (Size: 217.62 KB / Downloads: 16)
Yesterday 05:50 PM
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
